new snapshot (ss-20021118), etc
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Nov 18 22:48:18 UTC 2002
Ralf Corsepius wrote:
> Am Mon, 2002-11-18 um 22.46 schrieb Joel Sherrill:
> > Stephen Holford wrote:
> > > Hi
> > > As with the 20021111 snapshot, I get the following non-fatal configure
> > > errors with the 20021118 snapshot. I'm running redhat 7.1 with the
> > > latest autoconf (2.52) and automake (1.62) from the OAR site. The build
> > > process completes in spite of the errors. The 20021007 snapshot does not
> > > exhibit this behaviour.
> > Thanks for reporting this last time. Ralf is looking into it. He is
> > trying
> > to resolve conflicts between various versions of automake/autoconf and
> > this
> > is unfortunately a side-effect.
> True. However this problem only occurs if using whitespace separated
> lists as arguments to configure options,
> eg.
> configure .. --enable-rtemsbsp="foo bar"
> or
> configure .. --enable-bare-cpu-cflags="-Dfoo -Dbar"
> If not using whitespaces, everything should work out fine.
I am confused. Is this a configure invocation problem or the same
as PR312?
> > This will be fixed before we branch.
> > > I used the following command line:
> > > $ /home/rtems/tools/rtems-ss-20021118/configure --prefix=/opt/rtems
> > > --target=powerpc-rtems --disable-networking --disable-posix
> > > --disable-docs --disable-itron --disable-tests
> > > --enable-bare-cpu-cflags=-mcpu=603e -mstrict-align -Dmpc8260
> > > -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF
> This is quoted improperly. it should be
> --enable-bare-cpu-cflags="-mcpu=603e -mstrict-align -Dmpc8260
> -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF"
> > > --enable-bare-cpu-model=mpc8260 --enable-maintainer-mode
> > > --enable-rtemsbsp=bare
> Ralf
joel at OARcorp.com On-Line Applications Research
