machine label.
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Tue Nov 19 12:18:36 UTC 2002
Am Die, 2002-11-19 um 12.45 schrieb Chris Johns:
> Ralf Corsepius wrote:
> > Am Die, 2002-11-19 um 04.21 schrieb Chris Johns:
> > >Does a define exist that describes the "machine" ?
> > What do you mean by "machine", here?
> I suppose it is the label returned by "uname -m" on FreeBSD or which
> ever Unix.
Then POSIX's uname(2) is what you are looking for (cf.
cpukit/libcsupport/include/sys/utsname.h)
> > architecture/cpu?
> > cpu-variant?
> > OS?
> > uname?
> > There exist several defines and variables in RTEMS which could be used
> > for such purposes.
> This is what I was wondering. If it existed I would use it.
> > >This is for the global "extern char machine[];" that is found on
> > FreeBSD boxes.
> > This doesn't exist in RTEMS ;)
> Does in my code. I am porting the FreeBSD sysctl call :-)
Then I'd guess machine is an internal implementation detail of their
uname(2) implementation.
> > Do you want to destinguish RTEMS from other OSes?
> > Then you could use __rtems__ (defined by gcc).
> You may remotely via a protocol such as SNMP.
> It was a case of looking at what it takes to include these variables. If
> it is not worth including that is fine.
It depends, to switch between code parts at compile-time, you can rely
on __rtems__, it is automatically provided by rtems-gccs, and is
supposed to be user provided if not using gcc.
If you want some string at run-time, using uname would be what you
should be using (It's standardized and should be portable).
Ralf
