new snapshot (ss-20021118), etc
    Stephen Holford
    SHolford at WESCAM.com
    Tue Nov 19 13:43:48 UTC 2002
Hi Ralf
> Both.
> Stephen quotes improperly, which then triggers the bug. If he had quoted
> properly, a he would have encountered similar problems later.
Huh? How exactly am I mis-quoting?
env_var="A B C"
cmd --switch="${env_var}"
Is exactly equivalent to typing
cmd --switch="A B C" on the command line.
However we can illustrate this further.
Using my home system (Slackware 8.1), freshly installed stock virgin OAR
rpm's with no funny scripts or hacks I generated the following test
cases last night:
Case 1: command line quoting (exactly what my script does, what the
documentation suggests and is what one would naturally type at the
command line, and what has been deemed "Misquoting")
../rtems-ss-20021111/configure --enable-rtemsbsp="mbx8xx mpc8260ads"
Produces the following errors:
./rtems-ss-20021111/configure: eval: line 1: unexpected EOF while looking
for matching `''
../rtems-ss-20021111/configure: eval: line 2: syntax error: unexpected end
of file
etc. etc.
Config.log:
   $ ../rtems-ss-20021111/configure --enable-rtemsbsp=mbx8xx mpc8260ads
Resulting string in configure screen output:
''--enable-rtemsbsp=mbx8xx' 'mpc8260ads''
Snapshot 20021118 produces the same errors and output.
Case 2: command line escaped embedded quoting.
../rtems-ss-20021111/configure --enable-rtemsbsp="\"mbx8xx mpc8260ads\""
../rtems-ss-20021111/configure: eval: line 1: unexpected EOF while looking
for matching `''
of file
etc. etc.
Config.log:
   $ ../rtems-ss-20021111/configure --enable-rtemsbsp="mbx8xx mpc8260ads"
''--enable-rtemsbsp="mbx8xx' 'mpc8260ads"''
Case 3: Single quote with double quote embedded. Of course this is
really the same as Case 2 above.
../rtems-ss-20021111/configure --enable-rtemsbsp='"mbx8xx mpc8260ads"'
for matching `''
of file
etc. etc.
Config.log:
Case 4: Silly multiple quoting, perhaps illustrates how the quotes are
being passed through:
../rtems-ss-20021111/configure --enable-rtemsbsp='""""mbx8xx mpc8260ads""""'
for matching `''
of file
etc. etc.
Config.log:
   $ ../rtems-ss-20021111/configure --enable-rtemsbsp=""""mbx8xx
mpc8260ads""""
''--enable-rtemsbsp=""""mbx8xx' 'mpc8260ads""""''
Case 5: Any of the above with a single argument with a trailing space
(Just satisfying my curiosity):
../rtems-ss-20021111/configure --enable-rtemsbsp='"mbx8xx "'
for matching `''
of file
etc. etc.
Config.log:
   $ ../rtems-ss-20021111/configure --enable-rtemsbsp="mbx8xx "
''--enable-rtemsbsp="mbx8xx' '"''
Conclusion:
echo "\"It's dead Jim\""
Translation:
There is a problem in current RTEMS autoconf and it's nothing to do with
my quoting.
Take care,
Steve
> [Background: autoconf's internal quoting of configure arguments has
> changed. These quoted configure arguments are processed and passed down
> to subdirectory configure scripts. During this processing quoting of
> lists gets lost and causes them to be passed as separate arguments
> instead of one.]
> Ralf
