Anyone using ACE with RTEMS?
Thu Nov 21 14:02:00 UTC 2002
Phil .. your problem may be that no condition variables
are configured.
Jack Cawkwell wrote:
> Phil,
> I am hoping to use ACE/TAO under RTEMS, and tried to test it about
> 6 months ago. I am new to RTEMS and had trouble building for a number
> of reasons, and stopped so that I could continue to develop my application
> under Linux. Most of my app should work under Linux, so I am under no
> pressure. I could probably help with testing as I am in a better position
> to do the RTEMS build now. This is in support of a part-time PhD so time
> is in short supply ;=)
> I will also need to port the OpenCV library to RTEMS at some time. Has this
> been done by anyone, or does anyone know how difficult it might be?
What's OpenCV?
On a different note, OAR is happy to provide porting services to
anyone interested.
> Jack
> ptorre at zetron.com writes:
> >I'm trying to get the most recent stable ACE library to work with
> >rtems-ss-20020628, and wondered if anyone else has played with this.
> >RTEMS is one of the targets that ACE knows about, but I'm having a
> >few problems getting it going.  The current problem is that the
> >first thing ACE does is create a POSIX condition variable, and then
> >does a pthread_cond_wait() on it with no other threads running.  It
> >looks like RTEMS is doing everything it should, so I'm asking about
> >this on the ACE list also; just wondered if any RTEMS users had been
> >here before me.  :)
> >Thanks,
> >-Phil
> >Phil Torre                               phone: 425-820-6363 x234
> >Design Engineer                          email: ptorre at zetron.com
> >Switching Systems Group                    fax: 425-820-7031
> >Zetron, Inc.                               web: http://www.zetron.com
