memory footprint
Aaron J. Grier
aaron at frye.com
Tue Nov 26 19:13:04 UTC 2002
On Tue, Nov 26, 2002 at 12:15:45PM -0500, Wulf Hofbauer wrote:
> Well, I get about the same codesize for a null application...
this got me wondering...
(m68k, custom BSP, RTEMS 4.5.0, gcc 3.2.1)
> I was under the impression only those managers referenced in the
> code get linked.
the "minimum" example has all the managers enabled, so there's some
space right there...
> So the RTEMS philosophy is "start big, cut out what you don't need"
> instead of "start minimal, add only what you need"? Or am I getting
> this wrong again?
I think it depends primarily on who put the scripts (condefs and
Makefile options) together. ;) certainly the hooks are there to tune
things.
> > Out of interest what would seem right to you ?
> For a "null" program that doesn't use the C library or the RTEMS API,
> I think 32 kB would be acceptable, 16 kB would be reasonable, 8 kB
> would be good, and 4 kB would be excellent.
here's what I was able to do by setting MANAGERS = none and compiling
RTEMS with -DNDEBUG and -O4 -fomit-frame-pointer to avoid calls to
printf from assert().
text data bss dec hex filename
35144 2656 7592 45392 b150 o-optimize/minimum.exe
by disabling the console and termios, I was able to get it down to
32992 2656 7592 43240 a8e8 o-optimize/minimum.rxe
> Part of the problem is, on m68k, that there's a block of 9 kb of
> uninitialized data space embedded in the code section.
where?
> Still, even without that, the executable looks too large to me.
certainly worth some investigation.
Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
