RTEMS ss-20021004 Available
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Oct 4 20:30:47 UTC 2002
Hi,
A new snapshot is available at:
ftp://ftp.oarcorp.com/pub/rtems/snapshots/rtems/current
It includes the following:
+ a lot of automake/conf updates and fixes from Ralf,
+ the fix for PR267 (m68k _ISR_Nest_level,
+ fix for IMFS close of unlinked files leak,
+ ARM fixes for networking
+ IP Alias ioctl addition
+ MIPS gdb stub builds again
+ a LOT of Ada95 binding and test suite work
+ cvsignore-add shell script
Also of importance are two packaging changes. Formerly,
RTEMS versions consisted of 2 files. Now it is 4.
+ the source tarball itself
+ diff to the previous version
+ (NEW) diff of all ChangeLogs
+ (NEW) file describing host OS and tool versions
on the machine that cut the version.
joel at OARcorp.com On-Line Applications Research
