network freeze
Mário Vieira
mariovieira at netc.pt
Mon Oct 7 13:45:20 UTC 2002
Hi,
Thanks for your help.
My last experience with the network driver was made with interrups disabled. Nothing is received and
nothing is transmited. I wanted to test if there was something wrong with the estruture of the driver in the transmission process. I expected that when we run out of buffers some error
message will come up.
Best regards,
Mário Vieira
-----Mensagem original-----
De: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Enviada: seg 07-10-2002 14:20
Para: Mario Vieira
Cc: rtems-users at OARcorp.com
Assunto: Re: network freeze
Mario Vieira wrote:
> Hi,
> I'm trying to test the latest netdemo example downloaded from oarcorp
> in rtems 4.5.0 also downloaded from oarcorp. I'm using the i960
> processor.
> I run the netdemo program and the system freezes after sending 5 UDP
> packets. I see with a packet sniffer that after those 5 packets an ARP
> request is sent too.
> It seems that the network stack is wait for the answer to that ARP.
> Shouldn't the stack give some error?
This sounds distinctly like a network driver problem. On many NICs,
there is a set of buffers/descriptors on the chip itself that must
be recovered. If you don't do it properly, it will run a few packets
(usually < 50) and fail.
Another possibility is that you have gotten a different type of
interrupt
and are not handshaking it correctly.
> Thanks in advance,
> Mário Vieira.
> My network driver big picture (based in wd8003 driver from pc386 BSP)
> without sending anything to the network board:
> void
> wd_txDaemon (void *arg)
> struct wd_softc *sc = (struct wd_softc *)arg;
> struct ifnet *ifp = &sc->arpcom.ac_if;
> struct mbuf *m;
> rtems_event_set events;
> for (;;) {
> * Wait for packet
> rtems_bsdnet_event_receive (START_TRANSMIT_EVENT,
> RTEMS_EVENT_ANY | RTEMS_WAIT, RTEMS_NO_TIMEOUT, &events);
> * Send packets till queue is empty
> for (;;) {
> * Get the next mbuf chain to transmit.
> IF_DEQUEUE(&ifp->if_snd, m);
> if (!m)
> break;
> sendpacket (ifp, m);
> ifp->if_flags &= ~IFF_OACTIVE;
> static void
> sendpacket (struct ifnet *ifp, struct mbuf *m)
> struct wd_softc *dp = ifp->if_softc;
> struct mbuf *n;
> unsigned int len, tport;
> char *shp, txReady;
> len = 0;
> n = m;
> for (;;){
> len += m->m_len;
> /* memcpy(shp, (char *)m->m_data, m->m_len); */
> shp += m->m_len ;
> if ((m = m->m_next) == NULL)
> break;
> m_freem(n);
joel at OARcorp.com On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20021007/d2a08fc6/attachment.html>
