make vs. gmake
Tue Oct 8 20:29:08 UTC 2002
Steven Grunza wrote:
> How can I be certain that gmake is called during builds instead of the
> system's make?  That may be the source of my problems.
make --version
If it is GNU make, it will be obvious. :)
> Is there a command line option I need to pass to ./bootstrap ?
No.  If it doesn't work, then your automake/conf versions are
not correct for that version of RTEMS.
> "Unix is user friendly, it's just | Steven Grunza
> particular about with whom it     | voice:  (856) 787 - 2759
> makes friends."                   | fax:    (856) 866 - 2033
>   - Unknown                        | mailto:steven_grunza at ieee.org
