Is newlib-1.10 required for ss-20021007?
Phil Torre
ptorre at zetron.com
Tue Oct 8 23:04:34 UTC 2002
I'm trying to build ss-20021007 for powerpc, and the build is
breaking in cancelrun.c because PTHREAD_CANCELED is undefined.
I see this in the changelog:
2002-08-09 Joel Sherrill <joel at OARcorp.com>
* src/cancelrun.c: Remove check for PTHREAD_CANCELED not being
defined
to ensure that newlib patch includes it.
I have a bad feeling that I need to get a newer newlib with the patch
mentioned above? (That would be bad news for me, since I am marooned
at GDB-5.0 because my bdm debugger patch won't work with GDB 5.1 or
newer, which keeps me from moving up to gcc 3.x.)
If the above is correct, can I stick in a dummy define to get cancelrun.c
built without breaking something else, or am I out of luck?
Many thanks,
-Phil
Phil Torre phone: 425-820-6363 x234
Design Engineer email: ptorre at zetron.com
Switching Systems Group fax: 425-820-7031
Zetron, Inc. web: http://www.zetron.com
