How to configure GCC build for only C and C++
Wulf Hofbauer wh73 at cornell.edu
Thu Oct 10 03:19:28 UTC 2002
On Wed, Oct 09, 2002 at 05:12:22PM -0700, Till Straumann wrote:
> Wasn't that --enable-languages=c,c++ [note the 's']? AFAIK,
> unrecognized configure options are ignored, so these details
> are important...
Oops, you're correct.
- Wulf
Dr. Wulf Hofbauer (wh73 at cornell.edu)
Postdoctoral Associate, Dept. of Chemistry and Chemical Biology
Cornell University, B26 Baker Lab, Ithaca, NY 14853, USA
Phone: +1 607-255-4980 Fax: +1 607-255-0595
Return-Path: <gregmatu at poczta.onet.pl>
Mailing-List: contact rtems-users-help at oarcorp.com; run by ezmlm
Delivered-To: mailing list rtems-users at oarcorp.com
Received: (qmail 5500 invoked from network); 10 Oct 2002 06:53:14 -0000
Received: from unknown (HELO smtp3.poczta.onet.pl) (213.180.130.29)
  by 0 with SMTP; 10 Oct 2002 06:53:14 -0000
Received: from f25.test.onet.pl ([192.168.240.55]:49065 "EHLO f25.test.onet.pl")
	by ps3.test.onet.pl with ESMTP id <S847126AbSJJGwv>;
	Thu, 10 Oct 2002 08:52:51 +0200
Received: from localhost ([127.0.0.1] helo=l1.test.onet.pl)
	by f25.test.onet.pl with smtp mailer
	id 17zXBi-0001lr-00
	for <rtems-users at OARcorp.com>; Thu, 10 Oct 2002 08:52:50 +0200
Received: from 213.180.130.14 by 192.168.240.55 with HTTP; Thu, 10 Oct 2002 8:52:50 +0200
Received: from 193.59.197.38 by 213.180.130.14 with HTTP
To:	rtems-users at OARcorp.com
Date:	Thu, 10 Oct 2002 8:52:50 +0200
Content-Type:	text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7BIT
Content-Disposition: inline
Subject: Extra(?) tools
Mime-Version: 1.0
X-Mailer: onet.poczta
Message-Id: <E17zXBi-0001lr-00 at f25.test.onet.pl>
Hi all
I have question, perhaps stupid, but sorry I'm novice.
I installed ready packages of gcc and binutils grabbed from oarcorp
for 4.5.0 release.
And in directry /usr/local/bin exist tools like
i386-rtems-(ar, as etc..) on my FreeBSD.
Question:
What is purpose of tools in /usr/local/i386-rtems/bin/ directory?
Tools like ar, as, gcc etc.
Thanks in advance
Gregory Matus
mailto:
Received: (qmail 6052 invoked from network); 10 Oct 2002 06:56:35 -0000
Received: from unknown (HELO smtp2.poczta.onet.pl) (213.180.130.30)
  by 0 with SMTP; 10 Oct 2002 06:56:35 -0000
Received: from f26.test.onet.pl ([192.168.240.56]:5781 "EHLO f26.test.onet.pl")
	by ps2.test.onet.pl with ESMTP id <S848051AbSJJGza>;
	Thu, 10 Oct 2002 08:55:30 +0200
	by f26.test.onet.pl with smtp mailer
	id 17zXEH-0006Qu-00
	for <rtems-users at OARcorp.com>; Thu, 10 Oct 2002 08:55:29 +0200
Received: from 213.180.130.14 by 192.168.240.56 with HTTP; Thu, 10 Oct 2002 8:55:29 +0200
Date:	Thu, 10 Oct 2002 8:55:29 +0200
Subject: ELF error
Mime-Version: 1.0
Message-Id: <E17zXEH-0006Qu-00 at f26.test.onet.pl>
Hi all,
I installed freebsd packages for rtems release 4.5.0 grabbed from
ftp.oarcorp.com/pub/rtems/releases/4.5.0/c_tools/freebsd_x86/tgz/i386-rtems/
and I also downloaded rtems-4.5.0 release (no snapshot).
There were a few infos during rtems building:
ELF binary type "0" not known
What it means??
Sample - hallo.exe (I compile for pc386 bsp) which I found in samples
directory works.
But is huge, about 800kB (8 hundreds kilo bytes!).
Do I missed somthing?
Gregory Matus
mailto:
Received: (qmail 6791 invoked from network); 10 Oct 2002 06:59:47 -0000
  by 0 with SMTP; 10 Oct 2002 06:59:47 -0000
Received: from f28.test.onet.pl ([192.168.240.58]:36750 "EHLO f28.test.onet.pl")
	by ps2.test.onet.pl with ESMTP id <S847913AbSJJG7h>;
	Thu, 10 Oct 2002 08:59:37 +0200
	by f28.test.onet.pl with smtp mailer
	id 17zXIH-0007gb-00
	for <rtems-users at OARcorp.com>; Thu, 10 Oct 2002 08:59:37 +0200
Received: from 213.180.130.14 by 192.168.240.58 with HTTP; Thu, 10 Oct 2002 8:59:37 +0200
Date:	Thu, 10 Oct 2002 8:59:37 +0200
Subject: archive tarball
Mime-Version: 1.0
Message-Id: <E17zXIH-0007gb-00 at f28.test.onet.pl>
Hallo
Does packed(tared&gziped) form of mailing list archive exist?
And if where?
I preffer to search and read archive off-line?
Gregory Matus
mailto:
Received: (qmail 7960 invoked from network); 10 Oct 2002 07:56:49 -0000
  by 0 with SMTP; 10 Oct 2002 07:56:49 -0000
Received: from f26.test.onet.pl ([192.168.240.56]:42408 "EHLO f26.test.onet.pl")
	by ps3.test.onet.pl with ESMTP id <S845174AbSJJH4h>;
	Thu, 10 Oct 2002 09:56:37 +0200
	id 17zYBQ-0008Pi-00; Thu, 10 Oct 2002 09:56:36 +0200
Received: from 213.180.130.14 by 192.168.240.56 with HTTP; Thu, 10 Oct 2002 9:56:36 +0200
To:	Chris Johns <cjohns at cybertec.com.au>
Cc:	rtems-users at OARcorp.com
Date:	Thu, 10 Oct 2002 9:56:36 +0200
Content-Type: text/plain; charset="iso-8859-2"
Content-Transfer-Encoding: 8bit
Subject: Re: Extra(?) tools
Mime-Version: 1.0
Message-Id: <E17zYBQ-0008Pi-00 at f26.test.onet.pl>
U¿ytkownik Chris Johns <cjohns at cybertec.com.au> napisa³:
>gregmatu at poczta.onet.pl wrote:
>> Hi all
>> for 4.5.0 release.
>> Question:
>Did you build the tools from source ?
No, i used packages which I downloaded from oarcorp. This packages was for 4.5.0 release.
Gregory Matus
mailto: gregmatu at poczta.onet.pl
