problems compiling latest snapshoot
Chris Johns cjohns at cybertec.com.au
Mon Oct 21 13:11:58 UTC 2002
Vladimir Nesic wrote:
> m68k-rtems-gcc --pipe -B../../../../lib/ -B../../../../gen68360/lib/
> -specs bsp_specs -qrtems         -qrtems_debug -Wno-unused  -g -Wall
> -mcpu32  -o o-debug/capture-cli.o -c
> ../../../../../../rtems-ss-20021007/c/src/libmisc/capture/capture-cli.c
> ../../../../../../rtems-ss-20021007/c/src/libmisc/capture/capture-cli.c:
> In function `rtems_capture_task_time':
> ../../../../../../rtems-ss-20021007/c/src/libmisc/capture/capture-cli.c:1404:
> Internal compiler error in instantiate_virtual_regs_1, at
> function.c:3972
I get the error when doing the debug build on the cpu32 as you do. I did
not see the error on the o-optimize or o-debug build for the Coldfire
(-m5200).
After a little more testing the problem shows on:
  68040, 68030, 68020, cpu32
and passes on:
  68000, 68060, 5200
The -g option does not seem to make any difference so something else in
the code seems to trip the error.
I am not sure what the solution to this problem is.
 Chris Johns, cjohns at cybertec.com.au
