Does RTEMS support ARM series microprocessor ?
Wed Oct 23 13:32:41 UTC 2002
howard wrote:
> Thank you very much !
> I've found "RTEMS ARM Application Supplement"(arm.pdf) in
> ftp://ftp.oarcorp.com/pub/rtems/cd-working
> but I didn't find the source code (c language) for ARM.
> Where I can get the BSP for ARM.
All RTEMS ports are included in the same source package.
So it is in rtems-ss-DATE.tar.bz2.  CPU support is organized
into one of two directories based upon some rules I can
try to explain later.
  + cpukit/score/cpu/CPU_NAME
  + c/src/lib/libcpu/CPU_NAME
> If it could be , BSP for SAMSUNG ARM is better.
There seem to be 100s of ARM CPU models.  I don't think
there is one in the tree to match your precise model but
there are others that probably match the CPU core in it.
> Anyway , thanks a lot for your help !!!
No problem.
> Have a nice day ~
> Best Regards !
> Howard.
> ----- Original Message -----
> From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
> To: "howard" <howard at antek.com.tw>
> Cc: <rtems-users at OARcorp.com>
> Sent: Tuesday, October 22, 2002 8:48 PM
> Subject: Re: Does RTEMS support ARM series microprocessor ?
> > howard wrote:
> > Hi..
> >     I am new to RTEMS.
> >     I have a question . Does RTEMS support ARM series microprocessor ?
> Yes in post 4.5 snapshots.
> >     If not , how should I do ? porting it by myself ?
> >     Have anyone been ported it to ARM series microprocessor before ?
> Take a peek at the stuff in ftp://ftp.oarcorp.com/pub/rtems/cd-working
> which has the current RTEMS version along with prebuild arm-rtems
> tool RPMs.
> >     Please help me.
> >     Any suggestions will be appreciated !
> >     Thanks a lot !
> >     Have a nice day~
> >             Howard.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
