Problem building the ss20021007
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Oct 24 11:27:18 UTC 2002
Am Don, 2002-10-24 um 11.26 schrieb Paul Whitfield:
> Ralf Corsepius wrote:
> > Am Don, 2002-10-24 um 10.44 schrieb Paul Whitfield:
> >>Joe Samuel wrote:
> >>>Hi Paul,
> >>>    thank you for your valuable advice, but I'm still
> >>>stuck up with something else. Here's the relevant
> >>>build trace:
> >>>../cpukit/score/cpu/unix/cpu.c
> >>>rm -f o-optimize/libscorecpu.a
> >>>no ruv o-optimize/libscorecpu.a o-optimize/cpu.o
> >>>gmake[6]: no: Command not found
> >>Do you have a environment variable
> >>called AR set to NO?
> >>This could be the cause.
> > No, all this indicates that your PATH is set up wrong and that you are
> > trying to apply a non-functional or bogus toolchain.
> > Furthermore, you MUST NOT set CC or GCC nor AR, NM or whatever from your
> > environment before running configure - This definitely is wrong!
> Hi Ralf,
> Sorry if my advice was wrong, but certainly I have
> always had to (on older snap-shots, 4-5-0) set either create a
> link or set GCC=cc.
Hmm, the former is true for 4.5.0 under cygwin (It's a deficiency in
autoconf-2.13 causing problems), but I doubt the latter (GCC=cc),
because GCC is an interal autoconf variable used to denote if using GCC
or not.
The symlink/link/copy gcc->cc however should not be necessary with
rtems-snapshots (Untested, I am not using cygwin.), which uses a newer
autoconf where this autoconf problem is supposed to be solved.
> Before I offered this advice I did confirm that it works!
Odd.
Apologies if I may have sounded rude, but having to reiterate the same
answers twice a week is a bit annoying.
> As for the second problem I was suggesting that there was an
> INCORRECT environment variable AR that was set to NO!
Well, yes, this indicates a bug somewhere inside of the configuration,
however this actually points at two problems:
1. Why doesn't the configure script find the appropriate ar?
The cause for this probably is lurking somewhere in Joe's
environment/installation/setup.
2. The configuration should abort or complain explicitly if "ar" is not
found.
Ralf
Return-Path: <gregmatu at poczta.onet.pl>
Mailing-List: contact rtems-users-help at oarcorp.com; run by ezmlm
Delivered-To: mailing list rtems-users at oarcorp.com
Received: (qmail 18718 invoked from network); 24 Oct 2002 11:40:19 -0000
Received: from unknown (HELO smtp4.poczta.onet.pl) (213.180.130.28)
  by 0 with SMTP; 24 Oct 2002 11:40:19 -0000
Received: from f26.test.onet.pl ([192.168.240.56]:41898 "EHLO f26.test.onet.pl")
	by ps4.test.onet.pl with ESMTP id <S842700AbSJXLjm>;
	Thu, 24 Oct 2002 13:39:42 +0200
Received: from localhost ([127.0.0.1] helo=l1.test.onet.pl)
	by f26.test.onet.pl with smtp mailer
	id 184gL0-0002pj-00
	for <rtems-users at OARcorp.com>; Thu, 24 Oct 2002 13:39:42 +0200
Received: from 213.180.130.14 by 192.168.240.56 with HTTP; Thu, 24 Oct 2002 13:39:41 +0200
Received: from 193.59.197.38 by 213.180.130.14 with HTTP
To:	rtems-users at OARcorp.com
Date:	Thu, 24 Oct 2002 13:39:41 +0200
Content-Type:	text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7BIT
Content-Disposition: inline
Subject: Re: What tools to new snapsh (was: console -- serial console)
Mime-Version: 1.0
X-Mailer: onet.poczta
Message-Id: <E184gL0-0002pj-00 at f26.test.onet.pl>
>I have RTEMS 4.5.0 release and no this elegant tty_drv.:-(
>Unless you have some specific and good reasons (and if you're just
>starting out you don't) you shoudn't work with this old release.
>Use a recent snapshot instead.
>It will also help others to answer your questions: sources move.
I have a question regarding to shapshot esp. newest snapshot.
In file named readme or maybe used-tools of ss-20021007 is writen that was used rtems-base-binutils-### and <CPU>-rtems-binutils-### rpms.
Because I have freebsd not linux I found that there are sources of required binutils - but only one file , not two.
Do this are this two: base and processor specific in this one source file?
thera are not only binutils but also gcc-newlib in such 'situation'.
Gregory Matus
mailto: gregmatu at poczta.onet.pl
