Problem building RTEMS(m68k)
Sudheesh J
sudheesh at ATINAV.COM
Mon Oct 28 08:53:34 UTC 2002
Hi,
I'm new to both Makefiles and RTEMS. I found the documentation on RTEMS site very helpful. I followed the steps, though had some glitches in btw.
1) While installing the m68k-gdb, got a failed dependency, libncurses.so.4. I had libncurses.so.5 and forced the installation using --nodeps.
2) The listing of /opt/rtems/bin after the rpm installations was missing the c preprocessor, m68k-rtems-cpp.
3) The confgure command,
../rtems-ss-20021007/configure --target=m68k-rtems --enable-rtemsbsp=efi332 \
--disable-itron --enable-cxx --enable-tests --enable-docs --enable-networking
Went alright, but make produced the following output:( relevant parts only)
Making all in cpu
gmake[5]: Entering directory `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score/cpu'
Making all in m68k
gmake[6]: Entering directory `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score/cpu/m68k'mkdir o-optimize
gcc --pipe -isystem ../../../../../.././efi332/lib/include -O4 -fomit-frame-pointer
-g -Wall -mcpu32 -o o-optimize/cpu.o -c ../../../../../../../../rtems-ss-20021007/c/src/../../cpukit/score/cpu/m68k/cpu.c
In file included from ../../../../../../efi332/lib/include/rtems/score/cpu.h:23,
from ../../../../../../efi332/lib/include/rtems/system.h:138,
from ../../../../../../../../rtems-ss-20021007/c/src/../../cpukit/score/cpu/m68k/cpu.c:14:
../../../../../../efi332/lib/include/rtems/score/m68k.h:228:2: #error "Unsupported CPU model
-- are you sure you're running a 68k compiler?"
cc1: Invalid option `cpu32'
../../../../../../../../rtems-ss-20021007/c/src/../../cpukit/score/cpu/m68k/cpu.c: In function `_CPU_ISR_install_raw_handler':
../../../../../../../../rtems-ss-20021007/c/src/../../cpukit/score/cpu/m68k/cpu.c:110: warning: assignment makes pointer from integer without a cast
{standard input}: Assembler messages:
{standard input}:344: Error: invalid character '.' in mnemonic
gmake[6]: *** [o-optimize/cpu.o] Error 1
gmake[6]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score/cpu/m68k'
gmake[5]: *** [all-recursive] Error 1
gmake[5]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score/cpu'
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c/efi332'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c'
make: *** [all-recursive] Error 1
I had exported /opt/rtems/bin in PATH, but why the script still complaining abt a 68k compiler?
Is the missing m68k preprocessor causing the problem? Or is it because of a wrong configuration assumption that the -mcpu32 was used?
Expecting your comments,
Sudheesh
URL: <http://lists.rtems.org/pipermail/users/attachments/20021028/ebe95076/attachment.html>
