Problem building RTEMS(m68k)
Sudheesh J - Atinav Incorporated sudheesh at ATINAV.COM
Tue Oct 29 09:55:05 UTC 2002
I'm happy to convey that the problem was fixed with the use of the
sources+rtems patches.
But I haven't yet succeeded in building RTEMS.
First, an error message said:
../../../../../../../rtems-ss-20021007/c/src/../../cpukit/posix/src/cancelru
n.c:55: `PTHREAD_CANCELED' undeclared (first use in this function)
Then I added a
#ifndef
#define pair in pthread.h
But still it got stuck somewhere else.
m68k-rtems-gcc --pipe -isystem
./../../../dmv152/lib/include     -D_COMPILING_BSD_KERNEL_ -DKERNEL -DINET -
DNFS -DDIAGNOSTIC -DBOOTP_COMPAT      -O4 -fomit-frame-pointer -g -Wall   -o
o-optimize/kern_subr.o -c
../../../../../../../rtems-ss-20021007/c/src/../../cpukit/libnetworking/kern
/kern_subr.c
../../../../../dmv152/lib/include/rtems/rtems_bsdnet_internal.h:76: parse
error before `*'
../../../../../dmv152/lib/include/rtems/rtems_bsdnet_internal.h:76: warning:
data definition has no type or storage class
In file included from ../../../../../dmv152/lib/include/sys/systm.h:45,
                 from
/kern_subr.c:43:
../../../../../dmv152/lib/include/rtems/rtems_bsdnet_internal.h:105: parse
error before `rlim_t'
warning: data definition has no type or storage class
../../../../../dmv152/lib/include/rtems/rtems_bsdnet_internal.h:106: parse
error before `fixpt_t'
In file included from ../../../../../dmv152/lib/include/sys/systm.h:137,
                 from
/kern_subr.c:43:
../../../../../dmv152/lib/include/sys/libkern.h:58: parse error before
`qmax'
../../../../../dmv152/lib/include/sys/libkern.h:58: parse error before `a'
../../../../../dmv152/lib/include/sys/libkern.h: In function `qmax':
../../../../../dmv152/lib/include/sys/libkern.h:58: `a' undeclared (first
../../../../../dmv152/lib/include/sys/libkern.h:58: (Each undeclared
identifier is reported only once
../../../../../dmv152/lib/include/sys/libkern.h:58: for each function it
appears in.)
../../../../../dmv152/lib/include/sys/libkern.h:58: `b' undeclared (first
../../../../../dmv152/lib/include/sys/libkern.h:58: warning: control reaches
end of non-void function
../../../../../dmv152/lib/include/sys/libkern.h: At top level:
../../../../../dmv152/lib/include/sys/libkern.h:59: parse error before
`qmin'
../../../../../dmv152/lib/include/sys/libkern.h:59: parse error before `a'
../../../../../dmv152/lib/include/sys/libkern.h: In function `qmin':
../../../../../dmv152/lib/include/sys/libkern.h:59: `a' undeclared (first
../../../../../dmv152/lib/include/sys/libkern.h:59: `b' undeclared (first
../../../../../dmv152/lib/include/sys/libkern.h:59: warning: control reaches
/kern_subr.c: In function `uiomove':
/kern_subr.c:59: dereferencing pointer to incomplete type
/kern_subr.c:59: `UIO_READ' undeclared (first use in this function)
/kern_subr.c:59: `UIO_WRITE' undeclared (first use in this function)
/kern_subr.c:62: dereferencing pointer to incomplete type
/kern_subr.c:63: dereferencing pointer to incomplete type
/kern_subr.c:64: dereferencing pointer to incomplete type
/kern_subr.c:66: dereferencing pointer to incomplete type
/kern_subr.c:67: dereferencing pointer to incomplete type
/kern_subr.c:73: dereferencing pointer to incomplete type
/kern_subr.c:75: `UIO_USERSPACE' undeclared (first use in this function)
/kern_subr.c:76: `UIO_USERISPACE' undeclared (first use in this function)
/kern_subr.c:77: dereferencing pointer to incomplete type
/kern_subr.c:78: dereferencing pointer to incomplete type
/kern_subr.c:80: dereferencing pointer to incomplete type
/kern_subr.c:85: `UIO_SYSSPACE' undeclared (first use in this function)
/kern_subr.c:86:
/kern_subr.c:87:
/kern_subr.c:89:
/kern_subr.c:91:
`UIO_NOCOPY' undeclared (first use in this function)
/kern_subr.c:78:
warning: unreachable code at beginning of switch statement
/kern_subr.c:94:
/kern_subr.c:95:
/kern_subr.c:96:
/kern_subr.c:97:
gmake[5]: *** [o-optimize/kern_subr.o] Error 1
gmake[5]: Leaving directory
`/root/rtems/build_m68k/m68k-rtems/c/dmv152/exec/libnetworking/kern'
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
`/root/rtems/build_m68k/m68k-rtems/c/dmv152/exec/libnetworking'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
`/root/rtems/build_m68k/m68k-rtems/c/dmv152/exec'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c/dmv152'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c'
make: *** [all-recursive] Error 1
Is this some problem with the snapshot?
regards
Sudheesh
----- Original Message -----
From: "Sudheesh J - Atinav Incorporated" <sudheesh at ATINAV.COM>
To: "Joel Sherrill" <joel.sherrill at OARcorp.com>
Cc: <rtems-users at oarcorp.com>
Sent: Tuesday, October 29, 2002 10:02 AM
Subject: Re: Problem building RTEMS(m68k)
> Sorry, I missed out that in my last mail. When I tried to verify the
target
> tool set, the invalid assembler option error(as mentioned in the
> documentation) occured. I had installed the target tools from RPMs. Right
> now I'm trying the other way, that's using sources+ rtems patches.
>     Do I need to apply the patches even if I installed the target tools
from
> RPMS? I had the idea that the RPMS contain tools that are already patched.
> regards
> Sudheesh.
> From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
> To: "Sudheesh J" <sudheesh at ATINAV.COM>
> Sent: Monday, October 28, 2002 6:48 PM
> > > Sudheesh J wrote:
> > > Hi,
> > >         I'm new to both Makefiles and RTEMS. I found the documentation
> > > on RTEMS site very helpful. I followed the steps, though had some
> > > glitches in btw.
> > > 1) While installing the m68k-gdb, got a failed dependency,
> > > libncurses.so.4. I had libncurses.so.5 and forced the installation
> > > using --nodeps.
> > > 2) The listing of /opt/rtems/bin after the rpm installations was
> > > missing the c preprocessor, m68k-rtems-cpp.
> > > 3) The confgure command,
> > > ../rtems-ss-20021007/configure --target=m68k-rtems
> > > --enable-rtemsbsp=efi332 \
> > > --disable-itron --enable-cxx --enable-tests --enable-docs
> > > --enable-networking
> > > Went alright, but make produced the following output:( relevant parts
> > > only)
> > > Making all in cpu
> > > gmake[5]: Entering directory
> > > `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score/cpu'
> > > Making all in m68k
> > > gmake[6]: Entering directory
> > > `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score/cpu/m68k'mkdir
> > > o-optimize
> > > gcc --pipe -isystem ../../../../../.././efi332/lib/include
> > > -g -Wall -mcpu32  -o o-optimize/cpu.o -c
../../../../../../../../rtems-ss-20021007/c/src/../../cpukit/score/cpu/m68k/
> cpu.c
> > > ../../../../../../efi332/lib/include/rtems/score/cpu.h:23,
> > >                  from
> > > ../../../../../../efi332/lib/include/rtems/system.h:138,
> > >                  from
> cpu.c:14:
> > > ../../../../../../efi332/lib/include/rtems/score/m68k.h:228:2: #error
> > > "Unsupported CPU model
> > > -- are you sure you're running a 68k compiler?"
> > > cc1: Invalid option `cpu32'
> > ^^^^^^^  There's the big hint.  Now go back a few lines and notice the
> > name
> > of the compiler.  It is your native one not a m68k one.  Walk through
> > the items
> > in Chapter 5 -- "Building RTEMS" in the Getting Started manual.
http://www.oarcorp.com/rtems/doc-current/share/rtems/html/started/started000
> 24.html
> cpu.c:
> > > In function `_CPU_ISR_install_raw_handler':
> cpu.c:110:
> > > warning: assignment makes pointer from integer without a cast
> > > {standard input}: Assembler messages:
> > > {standard input}:344: Error: invalid character '.' in mnemonic
> > > gmake[6]: *** [o-optimize/cpu.o] Error 1
> > > gmake[6]: Leaving directory
> > > gmake[5]: *** [all-recursive] Error 1
> > > `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score'
> > > `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec'
> > > `/root/rtems/build_m68k/m68k-rtems/c/efi332'
> > > I had exported /opt/rtems/bin in PATH, but why the script still
> > >  complaining abt a 68k compiler?
> > > Is the missing m68k preprocessor causing the problem?  Or is it
> > > because of a wrong configuration assumption that the -mcpu32 was used?
> > >         Expecting your comments,
> > >     Sudheesh
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > Support Available                (256) 722-9985
