How to use mouse on pc386 bsp?
Jose Alves
josealves at HotPOP.com
Wed Oct 30 21:47:09 UTC 2002
I'm trying use the mouse driver in the pc386 bsp.
I have:
/* List of device drivers loaded by RTEMS at boot time */
rtems_driver_address_table Device_drivers[] =
CONSOLE_DRIVER_TABLE_ENTRY,
CLOCK_DRIVER_TABLE_ENTRY,
SERIAL_MOUSE_DRIVER_TABLE_ENTRY,
void GsSelect(void)
struct MW_UID_MESSAGE m;
int rc;
/* let's make sure that the type is invalid */
m.type = MV_UID_INVALID;
/* wait up to 100 milisecons for events */
rc = uid_read_message( &m, 100 );
/* return if timed-out or something went wrong */
if( rc < 0 )
if( errno != ETIMEDOUT )
printf( " rc= %d, errno=%d\n", rc, errno );
return;
switch( m.type )
/* Mouse or Touch Screen event */
case MV_UID_REL_POS:
case MV_UID_ABS_POS:
printf( "Mouse: btns=%X, dx=%d, dy=%d, dz=%d\n",
m.m.pos.btns, m.m.pos.x, m.m.pos.y, m.m.pos.z );
break;
default: ;
int rtems_ini()
int rc;
int mouse_fd;
/* if this is the first time around, create the message queue */
rc = uid_open_queue( Q_NAME, O_CREAT | O_RDWR, Q_MAX_MSGS );
mouse_fd = open( "/dev/mouse", O_NONBLOCK );
uid_register_device( mouse_fd, Q_NAME );
while( TRUE )
GsSelect();
return 0;
I'm not receiving messages from the mouse. I correctly configured the com port and mouse type.
An equivalent method works with the keyboard.
Could someone help me with any tip? or example code?
Thanks
Jose Alves
URL: <http://lists.rtems.org/pipermail/users/attachments/20021030/b92d2402/attachment.html>
