4.5.1-preview
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Oct 8 20:28:03 UTC 2002
I'm not joel at ieee.org so watch out when replying. :)
Steven Grunza wrote:
> What is the status of the pre-view? I was using a snapshot (20020301) but
> got hosed by the lack of configure.in files. I'm now trying to use the
> 4.5.1-pre3 tarball.
RTEMS snapshots are generally quite stable. Both 4.5.1 and
20020301 are quite old at this point so if you don't have all the
tools for them already installed, I would recommend going to
a more modern snapshot. I know that some of the older RPMs
are difficult to get installed on newers versions of Linux.
> The first two things I've found are:
> 1) that depcomp is missing from the top level (or not built correctly if
> it is the result of the bootstrap)
> 2) An incredible number of <AM_CPPFLAGS or TMPINSTALL_FILES etc) must be
> set with `=' before using `+=' warnings/errors
Sounds like an automake/autoconf version problem. Why don't you simply
try the latest snapshot and the tools that came with it?
> "Unix is user friendly, it's just | Steven Grunza
> particular about with whom it | voice: (856) 787 - 2759
> makes friends." | fax: (856) 866 - 2033
> - Unknown | mailto:steven_grunza at ieee.org
joel at OARcorp.com On-Line Applications Research
