autoconf/automake and bootstrap, was Re: make vs. gmake
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Wed Oct 9 06:48:45 UTC 2002
Hi,
in the last months many requests on the mailing list were due
to wrong automake/autoconf versions and bootstrap. Wouldn't it
be possible to check the correct automake/autoconf versions at
the beginning of "bootstrap", with a quite straightforward
error message if a non-matching version has been detected?
Maybe this could avoid lots of frustration to newbies...
wkr,
Thomas Doerfler.
> Steven Grunza wrote:
> > How can I be certain that gmake is called during builds instead of the
> > system's make? That may be the source of my problems.
> make --version
> If it is GNU make, it will be obvious. :)
> > Is there a command line option I need to pass to ./bootstrap ?
> No. If it doesn't work, then your automake/conf versions are
> not correct for that version of RTEMS.
> > "Unix is user friendly, it's just | Steven Grunza
> > particular about with whom it | voice: (856) 787 - 2759
> > makes friends." | fax: (856) 866 - 2033
> > - Unknown | mailto:steven_grunza at ieee.org
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_key.htm
