how to use loopback interface on rtems
Thu Oct 10 17:13:31 UTC 2002
Glen M Cornell wrote:
> http://www.ecst.csuchico.edu/~beej/guide/net/
> <http://www.ecst.csuchico.edu/%7Ebeej/guide/net/>
> Create a socket with the ip address set to 127.0.0.1.  Take a look at
> the above site for a tutorial on socket programming.  I suggest that you
> become familiar with socket programming in general (perhaps on a
> unix-like os) before you try do code for RTEMS.
I have attached a simple demo loopback interface test
that Eric Norum put together.  See if that helps.
> sudhir pola wrote:
> >Hai,
> >Can anyone help out how to use loop back interface on
> >rtems maybe with an example. I am using rtems 4.5
> >build and using leon processor. I currently testing my
> >applications using TSIM.
> >Thanks in advance ..
> >Sudhir
> >__________________________________________________
> >Do you Yahoo!?
> >Faith Hill - Exclusive Performances, Videos & More
> >http://faith.yahoo.com
Type: application/x-compressed
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20021010/5fabf525/attachment-0001.bin>
