problems compiling latest snapshoot
Chris Johns cjohns at cybertec.com.au
Mon Oct 21 11:34:24 UTC 2002
Vladimir Nesic wrote:
> Sorry, here are lines from log:
> m68k-rtems-gcc --pipe -B../../../../lib/ -B../../../../gen68360/lib/
> -specs bsp_specs -qrtems         -qrtems_debug -Wno-unused  -g -Wall
> -mcpu32  -o o-debug/capture-cli.o -c
> ../../../../../../rtems-ss-20021007/c/src/libmisc/capture/capture-cli.c
> ../../../../../../rtems-ss-20021007/c/src/libmisc/capture/capture-cli.c:
> In function `rtems_capture_task_time':
> ../../../../../../rtems-ss-20021007/c/src/libmisc/capture/capture-cli.c:1404:
> Internal compiler error in instantiate_virtual_regs_1, at
> function.c:3972
The code uses "long long". Maybe something is broken in GCC on the m68k
with this code. I developed it using a Coldfire target on the older GCC.
Seems a shame to remove "long long" support from the capture engine to
work around this but it may be better to have time in ticks and
tick_offset. This is how the time is maintained internally to the
capture engine. I will have to look into this, how-ever I do not think I
will have a solution quickly.
 Chris Johns, cjohns at cybertec.com.au
