Cannot find task id.
Niclas Johansson
nicjoh-7 at sm.luth.se
Wed Oct 23 14:21:05 UTC 2002
> Niclas Johansson wrote:
> > Yes on both.
> > This is the call:
> > task_status = rtems_task_ident(rtems_build_name('L','O','G','1'),
> > RTEMS_SEARCH_ALL_NODES, &taskid);
> > I find it strange that it works fine before I start the task but not
> > after.
> Sounds strange to me also. WOuld you mind putting together a
> small yet complete test program so I can run it and see what's
> happening. It sounds like it is only 4 calls -- create, ident,
> start, and a failing ident -- so it shouldn't be that difficult
> to get a cut-down.
OK, here is the code:
system.h:
#include <tmacros.h>
#include <signal.h>
#include <rtems/rtems/asr.h>
#include <rtems/score/isr.h>
#include <rtems/rtems/modes.h>
#include <rtems/rtems/signal.h>
/* functions */
rtems_task Init(
rtems_task_argument argument
/* configuration information */
#include <confdefs.h>
/* global variables */
TEST_EXTERN rtems_id Global_variable; /* example global variable */
rtems_task Application_task(rtems_task_argument argument);
/* end of include file */
init.c
#define TEST_INIT
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 50
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
#define CONFIGURE_MAXIMUM_SEMAPHORES 20
#define CONFIGURE_MAXIMUM_TASKS 25
#define CONFIGURE_MICROSECONDS_PER_TICK 10000
#define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
#define CONFIGURE_INIT_TASK_PRIORITY 120
#define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
RTEMS_NO_TIMESLICE | \
RTEMS_NO_ASR | \
RTEMS_INTERRUPT_LEVEL(0))
#include "system.h"
#include <time.h>
#include <rtems/error.h>
#include <rpc/rpc.h>
#include <netinet/in.h>
#include <time.h>
#include <arpa/inet.h>
#include <sys/socket.h>
/*#include "../networkconfig.h"*/
#include <rtems_webserver.h>
#include <rtems/monitor.h>
#define ARGUMENT 0
rtems_task Init(rtems_task_argument argument)
rtems_status_code status;
rtems_id tid, taskid;
status =
rtems_task_create(rtems_build_name('L','O','G','1'),1,RTEMS_MINIMUM_STACK_SIZE*2,RTEMS_PREEMPT
| RTEMS_
NO_TIMESLICE | RTEMS_NO_ASR |
RTEMS_INTERRUPT_LEVEL(0),RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,&tid);
if(status != 0)printf("id1 error\n");
printf("Log1Id in init.c:%i\n", taskid);
status = rtems_task_start(tid,Application_task,0);
taskid = 0;
if(status != 0)printf("id2 error \n");
status = rtems_task_delete( RTEMS_SELF );
apptask.c
rtems_task Application_task(rtems_task_argument argument){
printf("task started\n");
Thanks for helping! It is appreciated by a newbie!
/Nicke
> Thanks.
> --joel
> > /Nicke
> > On Wed, 23 Oct 2002 Per-Olof.Wallin at esa.int wrote:
> > > Per-Olof Wallin at ESA
> > > 10/23/2002 02:08 PM
> > > Are you using rtems_task_ident and if you are, did you use rtems_build_name
> > > to create the name?
> > > /Per-Olof
> > > | | Niclas |
> > > | | Johansson |
> > > | | <nicjoh-7 at sm.|
> > > | | luth.se> |
> > > | | 02-10-23 |
> > > | | 13:00 |
> > > | To: rtems-users at oarcorp.com |
> > > | cc: (bcc: Per-Olof Wallin/estec/ESA) |
> > > | Subject: Cannot find task id. |
> > > I am trying to find the id of a task from another task using
> > > rtems_task_ident. When the task is created it works fine and I get the
> > > id of the task, but when the task is started I get invalid
> > > name as error response. Anybody have any ideas? Getting the id seems to me
> > > like a straightforward operation but I cannot figure out what's wrong.
> > > /Nicke
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
