Cannot find task id.
Niclas Johansson
nicjoh-7 at sm.luth.se
Thu Oct 24 07:27:58 UTC 2002
On Thu, 24 Oct 2002, Ian Caddy wrote:
> Hi Niclas,
> Your application task does not stay in a loop, and hence will complete
> straight away.
> In this case, your Application task will complete after the printf and
> then will be deleted.
> Therefore if it is a higher priority task than your init task, it will
> be deleted before your init task will to the last ident.
> To fix this you will need to add (to your application task)
> while(1)
> rtems_task_wkafter(100);
> Then it will not end.
> I hope this helps,
> Ian Caddy
It helps very much! Thank you
for answering my stupid question! =)
