Problem building the ss20021007
Paul Whitfield
paulw at microsol.iinet.net.au
Thu Oct 24 07:56:07 UTC 2002
Hi Joe,
Joe Samuel wrote:
> Hi,
> When I tried the following command, I got the
> following output.
> # gcc -v
> Reading specs from
> /usr/lib/gcc-lib/i386-redhat-linux/2.96/specs
> gcc version 2.96 20000731 (Red Hat Linux 7.1 2.96-81)
> But when I tried to configure RTEMS, I got the
> following error.
> checking for style of include used by gmake... GNU
> checking for i386-pc-linux-gcc... no
> configure: error: no acceptable cc found in $PATH
> configure: error: /bin/sh
> '../../../../rtems-ss-20021007/c/make/configure'
> failed for c/make
> sed: can't read confdefs.h: No such file or directory
> ../rtems-ss-20021007/configure --target=i686-pc-linux
> --disable-itron --enable-tests
> --enable-cxx --enable-networking
> I used the configure command with the options as in
> the following.
> #../rtems-ss-20021007/configure --target=i386-pc-linux
> Can anyone comment on why the above error occurred.I'm
> using RedHat Liux 7.1(Newbie to auttools)
It sounds like the problem is that you need to
tell configure that CC is actually gcc
You can achieve this by either creating a
link from GCC to CC
ln -s /usr/bin/gcc /usr/bin/cc
(As root)
OR
export CC=gcc ../../../../rtems-ss-20021007/c/make/configure
Either of these should solve the problem
Regards
Paul
