build rtems
Heng Chun Meng
engp1017 at nus.edu.sg
Sat Oct 26 17:37:08 UTC 2002
Is there anyway to confirm that? From my understanding on the
steps described in the "getting started with RTEMS for C/C++ users"
documentation, I'm confident that those tools have been built successfully.
I have no idea what else to check. :(
Thanks alot.
_hcm_
-----Original Message-----
Sent: Saturday, October 26, 2002 6:38 PM
To: Heng Chun Meng; rtems-users at oarcorp.com
Subject: Re: build rtems
I *think* you either haven't buillt the necessary tools yet (ie
rtems-binutilities, rtems-gcc, etc)
or they are not present within your PATH.
Salman
----- Original Message -----
To: <rtems-users at oarcorp.com>
Sent: Saturday, 26 October, 2002 7:23 AM
Subject: build rtems
Hi all;
Can anyone help me on this, i'm lost.
I got these messages while building the rtems4.5.0 using the bit script.
running /bin/sh
../../../4.5.0/tools/build/configure --target=i386-rtems --pref
ix=/opt/rtems --disable-hwapi --enable-multiprocessing --enable-cxx --enable
-rdb
g --disable-tests --enable-networking --enable-posix --enable-itron --cache-
file
=../.././config.cache --srcdir=../../../4.5.0/tools/build
loading cache ../.././config.cache
checking for RTEMS Version... 4.5.0
checking host system type... i386-pc-cygwin32
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... (cached) yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking whether to enable maintainer-specific portions of Makefiles... no
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... configure: error: installation or
configuratio
n problem: compiler cannot create executables.
configure: error: ../../../4.5.0/tools/build/configure failed for
tools/build
Could not successfully configure into build-i386-rtems!
What could be wrong?
Thanks in advance.
_hcm_
