Undefined reference to rtems_bsdnet_config
Eric Norum
eric.norum at usask.ca
Thu Oct 31 18:24:01 UTC 2002
On Friday, November 1, 2002, at 01:41 AM, Sudheesh J wrote:
> Hi,
> Sorry for bugging you again. While trying to build a simple
> networking app, an undefined reference to rtems_bsdnet_config was
> produced.
> I'm using m68k bsk efi332.
> thank you for any help.
This structure contains the network configuration information. You
need to provide this as part of your application. Here's a simple
example. A more thorough example can be found in the network demo
programs.
BTW -- What network interface are you using?
This is from init.c:
* Network configuration
#define NETWORK_TASK_PRIORITY 50
static struct rtems_bsdnet_ifconfig netdriver_config = {
RTEMS_BSP_NETWORK_DRIVER_NAME,
RTEMS_BSP_NETWORK_DRIVER_ATTACH
struct rtems_bsdnet_config rtems_bsdnet_config = {
&netdriver_config, /* Network interface */
rtems_bsdnet_do_bootp, /* Use BOOTP to get network configuration */
NETWORK_TASK_PRIORITY, /* Network task priority */
256*1024, /* MBUF space */
512*1024, /* MBUF cluster space */
* RTEMS Startup Task
rtems_task
Init (rtems_task_argument ignored)
* Start network
rtems_bsdnet_initialize_network ();
Eric Norum <eric.norum at usask.ca>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394 FAX: (306) 966-5407
