Anyone using RTEMS on Motorola ColdFire (e.g. MCF5272)?
Andrew Sinclair andrews at elpro.com.au
Mon Sep 2 23:14:44 UTC 2002
Hello all,
I am a newbie to RTEMS, and it seems that I am in the same "boat" as what
Maarten was a year ago. So, I was wondering if anyone has ported a bsp to the
MCF5272C3 board in the year since these emails?
Any feedback would be much appreciated.
Regards,
Andrew Sinclair
Date: Fri, 14 Sep 2001 09:44:01 -0500
Hi Maarten,
Please check out the following URL.  The web page has some
very useful information about Motorola Coldfire development.
At this web site there is a link to the Netburner site and
some old information about RTEMS.
http://www.fiddes.net/coldfire/
Also, I do not think you will be able to use the RPM binary
versions of the GNU tools for Coldfire development.  This
web site has some patches that must be applied to gcc for the
coldfire.  And you will also want Chris John's gdb-bdm patches.
I am working using a Coldfire 5206e evaluation board.  Below
are the versions of the tools that I am using (built from the
source code).
 1) binutils-2.10 with Coldfire patches and RTEMS patch 2000-11-07
 2) gcc-2.95.3 with Coldfire patches and RTEMS patch 2001-03-14
 3) newlib-1.9.0 with Coldfire patches and RTEMS patch 2001-06-22
 4) rtems snapshot 2001-08-16
Good Luck
Mike Siers
> -----Original Message-----
> From: Maarten.Kruger at ziton.spx.com [mailto:Maarten.Kruger at ziton.spx.com]
> Sent: Friday, September 14, 2001 7:22 AM
> To: rtems-users at OARcorp.com
> Subject: RE: Anyone using RTEMS on Motorola ColdFire (e.g. MCF5272)?
> Good day,
> Could you provide me with a link to this Netburner 5272 board?  Is it very
> similar to the MCF5272C3 evaluation board?  How long do you think porting
> the BSP will take (I'm a total newbie...)
> I have downloaded RTEMS and installed the tools, as well as ordered the
> MCF5272C3 board, so I'm comitted now...
> thanks
> Maarten Kruger
> "Brett Swimley" <brett.swimley at aedinc.net> on 2001/08/24 04:01:16 PM
> Please respond to <brett.swimley at aedinc.net>
> To:   <Maarten.Kruger at ziton.spx.com>
> cc:
> I'm in the process of doing an RTEMS port for the Netburner 5272 board.
> I'll
> be submitting shortly.  This should be readily adaptable to the Motorola
> eval board.
> Regards,
> Brett Swimley
> Sent: Friday, August 24, 2001 6:09 AM
> To: rtems-users at oarcorp.com
> Subject: Anyone using RTEMS on Motorola ColdFire (e.g. MCF5272)?
> Good day,
> Thank you for the overwhelming response on my question of using RTEMS for
> powerPC...  It seems that the Motorola ColdFire may be more
> appropriate for
> my needs - is anybody using an existing port of RTEMS for the ColdFire?
> (e.g. MFC5272C3 evalutation board?)
> thanks
> Maarten Kruger
