Success using the IDE code
Peter Mueller
peter.o.mueller at gmx.de
Fri Sep 6 16:14:16 UTC 2002
Hi Joel, Thomas,
the only changes I made are in the hardware related code and in the structs used to access the IDE register set. No changes in other files.
The idea with Oktoberfest is not bad, but as far as I know is Thomas from Stuttgart. It may be better to meet at Canstatter Wasen :-)
Btw: is there a (simple) NFS available for rtems? I need a way to copy files via network to my rtems driven harddrive.
Peter
On Thu, 05 Sep 2002 20:24:18 -0500
Joel Sherrill <joel.sherrill at OARcorp.com> wrote:
> YEAH!!! Amazing!!! YEAH!!! Are there any changes that need to be made?
> I would suggest you both have a beer and celebrate but with Oktoberfest
> coming up, I expect you already have some planned. :)
"This is an object-oriented system.
If we change anything, the users object."
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020906/789f107d/attachment.bin>
