Insufficient memory for stack/FP context
Chris Welch
cwelch at neumes.com
Tue Sep 10 20:41:35 UTC 2002
I'm hitting a ceiling with the number of tasks I can create. I start
getting an RTEMS_UNSATISFIED error (not enough memory for stack/FP context).
What do I need to change to increase the memory available for the stack/FP
context?
I've had disasterous results so far increasing the heap size and/or
increasing the task space using CONFIGURE_EXTRA_TASK_STACKS (processor bus
errors). I expect I've got to fix up this problem, however, in the mean
time I'd like to know if I'm headed in the right direction.
Thanks much!
Chris Welch, Neumes Consulting, PC and UNIX Solutions
mailto:cwelch at neumes.com
613)797-7831 FAX:(613)838-5602
http://www.neumes.com
Name: Chris Welch.vcf
Type: text/x-vcard
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020910/68dd7b67/attachment.vcf>
