Problem with _TOD_Set
Chris Johns cjohns at cybertec.com.au
Fri Sep 20 00:10:11 UTC 2002
rtems wrote:
> Before the patch we are unable to obtain a NTP synchronization between
> different CPUs on Ethernet network better then 1 Sec
This is what was happening with the TOD set code.
> After the patch we are capable to obtain synchronization in term of 1
> tick system CPU clock between CPUs.
>  Can anyone confirm the problem or is  there an error in our analysis?
I can confirm the problem and a patch has been in CVS since the
7-Aug-2002. The patch in CVS is (sorry about being pasted):
RCS file: /usr1/CVS/rtems/cpukit/score/src/coretodset.c,v
retrieving revision 1.2
retrieving revision 1.3
diff -c -r1.2 -r1.3
*** rtems/cpukit/score/src/coretodset.c	1999/11/17 17:50:39	1.2
--- rtems/cpukit/score/src/coretodset.c	2002/08/07 15:03:52	1.3
*** 9,15 ****
    *  found in the file LICENSE in this distribution or at
    *  http://www.OARcorp.com/rtems/license.html.
!  *  $Id: coretodset.c,v 1.2 1999/11/17 17:50:39 joel Exp $
!  *  $Id: coretodset.c,v 1.3 2002/08/07 15:03:52 joel Exp $
*** 50,57 ****
          seconds_since_epoch - _TOD_Seconds_since_epoch );
     ticks_until_next_second = _TOD_Ticks_per_second;
!   if ( ticks_until_next_second > _TOD_Current.ticks )
!     ticks_until_next_second -= _TOD_Current.ticks;
     _TOD_Current             = *the_tod;
     _TOD_Seconds_since_epoch = seconds_since_epoch;
--- 50,57 ----
!   if ( ticks_until_next_second > the_tod->ticks )
!     ticks_until_next_second -= the_tod->ticks;
  Chris Johns, cjohns at cybertec.com.au
