How to make pipe on RTEMS?
Eric Norum eric.norum at usask.ca
Mon Sep 23 16:15:25 UTC 2002
On Monday, September 23, 2002, at 09:40 AM, Vladimir Nesic wrote:
> On Friday 20 September 2002 18:18, Eric Norum wrote:
>> I've attached the little test program I wrote to verify the network
>> stack code without using a network interface.  Perhaps it may be of
>> some help to you.
> When I was first answering this message on friday if was Friday, too
> late for work :(
> Today I have checked out the code You sent to me, and did some more
> digging throug RTEMS source code and have two questions:
> 1. Is it possible to connect two sockets without driving them through
>    ports?
I'm not quite sure what you're asking, but I think the answer to your
question is no.
Before a socket can be passed to connect() or accept() it must be bound
to an address.  The RTEMS port of the BSD stack supports only AF_INET
addresses which are defined by an IP number and a port number.  You can
have the system pick a port number for you (the example code does this).
>    2. Is it possible to connect two socekts without without starting
> another thread?
I suppose so,  but I thought you wanted to use these pipes (sockets)
for interthread communication.
> -- or --
> 1. If I implement pipe without using sockets, how much work does it
> take
>    to make select() function respond to it?
I think that implementing select() on top of something like RTEMS
message queues would be difficult,  especially if you wanted to be able
to simultaneously select on socket descriptors as well.
Eric Norum <eric.norum at usask.ca>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394   FAX:   (306) 966-5407
