Problems related to TOD_set and new problem with _Watchdog_Tickle (system hang).
Fabrizio Pirovano rtems.thysys at tiscalinet.it
Tue Sep 24 21:31:18 UTC 2002
My target is based on a Motorola 5272 CPU.
I received the patch from Chris and I am testing it but I need more then 2-3
days of continuos stress
running to be sure that the problem is missed.
In any case I think that the  Chris  patch is very important  and pertinent
to my problems.
When rtems will be fixed?
I verified that in snapshot 20020807 the patch was not present.
And more, I apologize but what is PR267 ?
I suppose that is a PRoblem-code but where  I can find them ?
thanks & regards
Fabrizio Pirovano
----- Original Message -----
From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
To: "Fabrizio Pirovano" <rtems.thysys at tiscalinet.it>
Cc: <rtems-users at oarcorp.com>
Sent: Tuesday, September 24, 2002 2:38 PM
Subject: Re: Problems related to TOD_set and new problem with
> Fabrizio Pirovano wrote:
> > Hi, Chris,
> > I verified the problem with the following snapshot:
> > ss-20020424
> > ss-20020528
> > ss-20020628
> > with the same results.
> What CPU are you using?  If it is a m68k, then this would be
> PR267 which Bretty Swimley, Eric Norum, and Chris fixed
> mid-Aug.
> If you are not on an m68k family CPU, then I have no ideas
> this morning
> > Regards
> > Fabrizio Pirovano
> > pirovano.thysys at tiscalinet.it
> > From: "Fabrizio Pirovano" <pirovano.thysys at tiscalinet.it>
> > To: "Chris Johns" <cjohns at cybertec.com.au>
> > Sent: Tuesday, September 24, 2002 10:06 AM
> > > Hi, Chris,
> > > ss-20020424
> > > ss-20020528
> > > ss-20020628
> > > Regards
> > > Fabrizio Pirovano
> > > From: "Chris Johns" <cjohns at cybertec.com.au>
> > > Sent: Tuesday, September 24, 2002 3:10 AM
> > > > > Can anyone confirm similar critical problem?
> > > > Not sure. A problem with the interrupts and the watchdog tickle was
> > > > fixed recently.
> > > > Which version of RTEMS are you using ?
> > > > Regards
> > > >   Chris Johns, cjohns at cybertec.com.au
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
