Redirecting stdout using dup/dup2
Olof Larsson larsso at space.se
Wed Sep 25 15:08:55 UTC 2002
Hi,
Nope, both of them fail, and as Eric Norum confirmed, they seem to be broken.
He provided me with a nice workaround, though. (Many thanks to all of you for
your help!)
Olof
On Wed, 25 Sep 2002, jennifer averett wrote:
> Does the Psx13 test work with the version you are running?
> This test uses dup and dup2.
> Jennifer
> Joel Sherrill wrote:
> > Jennifer... can you add anything to this?
> > Olof Larsson wrote:
> > > Hi all,
> > > Does anyone know if redirecting stdout to a socket using dup2 or dup is
> > > supposed to work? Something along the following:
> > > fd = accept(...)
> > > dup2(fd,1)
> > > printf("foo");
> > > It works fine in Linux, but unfortunately I get nothing through on the
> > > receiving side when I try the same thing in RTEMS.
> > What about the new descriptor returned by dup2?
> > I thought this type of trick had been done before.  Maybe someone
> > can confirm this.
> > Can you do this without trying a socket
> > The code for dup() and dup2() start in cpukit/libcsupport/src/dup*.c
> > and both end up going through fcntl(..F_DUPFD..)
> > (cpukit/libcsupport/src/fcntl.c).  If this isn't working, then
> > the copying going on may not be deep enough.
> > I also don't see a close in dup2() which I think should be done
> > between the 2nd fstat() and fcntl() if I read the Linux man page
> > correctly.
> > If you can figure out what is broken, a patch would be appreciated.
> > > Thanks
> > > Olof
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > Support Available                (256) 722-9985
