Socket blocking/non-blocking access puzzle.
Sergei Organov osv at javad.ru
Fri Sep 27 15:31:51 UTC 2002
Eric Norum <eric.norum at sasktel.net> writes:
> > Inclusion of the changes into the main RTEMS source tree is also
> > encouraged.
> I don't think that it is a good idea for RTEMS to deviate too far from the
> BSD stack semantics.
I agree and don't insist in any way that the change is include into the
RTEMS.
> Would your application work if you chose a very small, but non-zero, value
> for the SO_SNDTIMEO value?
Unfortunately I don't think it would. If tick is 10ms the actual delay will be
in the range 0-10ms for each write, but even 10ms total is not acceptable.
BR,
Sergei.
