(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Angelo Fraietta
angelo_f at bigpond.com
Wed Apr 9 05:10:23 UTC 2003
I have tried to build and run my application, however, the patch for the
IDE has redirected my console to com1.
I require both the console and com 1.
What do I need to do to change it back?
Angelo Fraietta wrote:
> Thomas Doerfler wrote:
>> Hello Angelo,
>> the "sample" program is located in the patch filed in the gnat system
>> as PR369. So if you go to
>> http://www.oarcorp.com/cgi-bin/gnatsweb.pl
>> and inspect PR369 and download/apply the patch and then look into
>> c/src/tests/samples/fileio, you will see the sample application.
>> BTW, you will also need PR368 and PR367 to get everything running
>> (these PRs contain modifications for the DOSFS code and added drivers
>> for PC386 and MBX8xx).
>> wkr,
>> Thomas.
> I have downloaded all the patches and performed the build, however,
> the sasmple is not being built.
> I also configured with --enable-tests, but still the sample was not
> built.
> I tried to build it using a makefile, however, I got a compile error
> unable to include /rtems/ata.h
> I looked in the install directories, however, ata.h is not there (it
> is in the source directory)
> Do I have to do something special in the configure to build this?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
