DOSFS and Smartmedia
Victor V. Vengerov
vvv at oktet.ru
Wed Apr 9 18:59:19 UTC 2003
Brett,
I'm not sure technical details about SmartMedia interface. As I know,
CompactFlash cards has IDE emulation mode, therefore ata driver may
be used for it; you need to implement board-specific libchip driver only.
If SmartMedia supports no IDE emulation, you have to implement
the block device driver. You may look cpukit/libblock/src/ramdisk.c
and cpukit/libblock/include/ramdisk.h as very simple example of
disk device driver.
Basically, block device driver should provide initialization and ioctl
function. Minimally, BLKIO_REQUEST ioctl command should
be implemented.
Look for request structure description in
cpukit/libblock/include/rtems/blkdev.h
Regards,
Victor
Brett Swimley wrote:
>Hello all,
>This may have gone out already, but I think I was having some mail problems.
>I'm tasked with interfacing to a Smartmedia FLASH card and need to write a
>driver to communicate with the Smartmedia card.
>I'm just now beginning to look at the literature and it appears that the
>recommeded file format for Smartmedia is the DOS FAT format.
>Does anyone have any notion as to whether the DOSFS implementation would be a
>starting point for the correct interface to the SmartMedia? If so, then would
>the best bet be to have the SmartMedia device driver look like a block device,
>or would it be best to emulate some other interface such as IDE or ATA?
>Any information or suggestions would be of great help!
>wkr,
>Brett Swimley
Victor V. Vengerov
OKTET Ltd.
Ulianovskaya st., 1, office 533, St.-Petersburg 198504 Russia
phone: +7 812 4284384 (work), +7 812 9389372 (mobile), +7 812 4281653 (home)
