SORRY!! Re: (Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Angelo Fraietta
angelo_f at bigpond.com
Thu Apr 10 01:58:44 UTC 2003
Thanks. Although this has fixed that problem, I still can't run my
application. It has nothing to do with your patches (I also checked . I
am getting an exception 6 error during startup. I will wait until the
new gcc3.2.3 comes out.
Thomas Doerfler wrote:
>Hello Angelo,
>so I really broke it!!!!
>In the patch of PR368, some modifications I implemented since
>I needed them for tests were still there. The following lines
>should NOT be part of the patch:
>diff -x '*~' -x Makefile.in -x configure.in -x configure -x
>autom4te.cache -P -r -u rtems-
>4.6.0pre1/c/src/lib/libbsp/i386/pc386/console/console.c rtems-
>4.6.0pre1-ide/c/src/lib/libbsp/i386/pc386/console/console.c
>--- rtems-
>Wed Jul 17 00:32:54 2002
>+++ rtems-4.6.0pre1-
>ide/c/src/lib/libbsp/i386/pc386/console/console.c Thu Feb
>27 10:25:38 2003
>@@ -61,8 +61,13 @@
> * to same serial device it does not work that great
>+#if 0 /* IMD hack */
> int BSPConsolePort = BSP_CONSOLE_PORT_CONSOLE;
> int BSPPrintkPort = BSP_CONSOLE_PORT_CONSOLE;
>+#else
>+int BSPConsolePort = BSP_UART_COM1;
>+int BSPPrintkPort = BSP_UART_COM1;
>+#endif
>To fix it, either change "#if 0" to "#if 1", or remove the
>unnecessary stuff completely, so that only the lines
>are left in your "console.c"
>Sorry again. I will open a PR on that right now..
>wkr,
> Thomas.
>>I have tried to build and run my application, however, the patch for the
>>IDE has redirected my console to com1.
>>I require both the console and com 1.
>>What do I need to do to change it back?
>>>>Hello Angelo,
>>>>the "sample" program is located in the patch filed in the gnat system
>>>>as PR369. So if you go to
>>>>http://www.oarcorp.com/cgi-bin/gnatsweb.pl
>>>>and inspect PR369 and download/apply the patch and then look into
>>>>c/src/tests/samples/fileio, you will see the sample application.
>>>>BTW, you will also need PR368 and PR367 to get everything running
>>>>(these PRs contain modifications for the DOSFS code and added drivers
>>>>for PC386 and MBX8xx).
>>>>wkr,
>>>> Thomas.
>>>I have downloaded all the patches and performed the build, however,
>>>the sasmple is not being built.
>>>I also configured with --enable-tests, but still the sample was not
>>>built.
>>>I tried to build it using a makefile, however, I got a compile error
>>>unable to include /rtems/ata.h
>>>I looked in the install directories, however, ata.h is not there (it
>>>is in the source directory)
>>>Do I have to do something special in the configure to build this?
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>>http://www.users.bigpond.com/angelo_f/
>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>There are those who seek knowledge to be known by others - that is VANITY
>>There are those who seek knowledge in order to serve - that is LOVE
>> Bernard of Clairvaux (1090 - 1153)
>IMD Ingenieurbuero fuer Microcomputertechnik
>Thomas Doerfler Herbststrasse 8
>D-82178 Puchheim Germany
>email: Thomas.Doerfler at imd-systems.de
>PGP public key available at: http://www.imd-
>systems.de/pgp_keys.htm
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20030410/758dea61/attachment.html>
