rtems-ss-20030411 available
Angelo Fraietta angelo_f at bigpond.com
Mon Apr 14 04:52:07 UTC 2003
I am still having trouble with this build, however, ticker runs with
this snapshot.
I have run through some tests of my libraries and have found that if I
include some standard c++, the program crashes bloats right out and then
with an exception 6.
For example, I have a simple application that creates and runs some
threads and works fine.
If, however, I do
#include <iostream>
in the module, the executable increases by 160K even though I don't
actually call any functions from iostream -- I just include the header.
When I try to run the program, it crashes with an exception 6 just after
the device drivers are initialised.
Is anybody else seeing this problem or similar? What is exception 6 on
pc386?
Joel Sherrill wrote:
>Hi all,
>Since putting out a new cd-working takes so much disk space, I
>decided to cut a new snapshot.  This is very close to what is
>on the release branch except that it includes some items
>not deemed safe enough for a release such as the GoAhead
>update and it officially removes the AMD A29K support.
>The next snapshot will remove the hppa 1.1 support unless someone
>complains and really helps support it.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
