I isn't able to compile a simple hello_world with Cygwin
silverio.di at qem.it silverio.di at qem.it
Tue Apr 15 14:51:39 UTC 2003
Hi,
I've some problems to compile a very simple hello_world apps
(not with RTEMS matter yet). This is the steps that I've followed:
- download of complete Cygwin tool-chain on PC directory
- installation of Cygwin from directory onto c:\bin\cygwin
- download of following files from FTP OARCORP (working cd directory):
    rtems-base-binutils-2.13.2.1-2.tar.bz2
    rtems-base-gcc-gcc3.2.1newlib1.11.0-2.tar.bz2
    m68k-rtems-binutils-2.13.2.1-2.tar.bz2
    m68k-rtems-c++-gcc3.2.1newlib1.11.0-2.tar.bz2
    m68k-rtems-gcc-gcc3.2.1newlib1.11.0-2.tar.bz2
- start of cygwin environment
- copy of all rtems files onto root directory
- unpack of rtems files between followin command:
   tar -xjf <rtems_file>
  in following order:
  1°)   rtems-base-binutils-2.13.2.1-2.tar.bz2
  2°) rtems-base-gcc-gcc3.2.1newlib1.11.0-2.tar.bz2
  3°)  m68k-rtems-binutils-2.13.2.1-2.tar.bz2
  4°)  m68k-rtems-c++-gcc3.2.1newlib1.11.0-2.tar.bz2
  5°)  m68k-rtems-gcc-gcc3.2.1newlib1.11.0-2.tar.bz2
  THANK YOU
