Multiple ethernet devices
gregory.menke at gsfc.nasa.gov
Wed Apr 16 20:24:23 UTC 2003
Hi,
I'm beavering away at the 3com driver- based on the Netbsd code so
that everyone will be happy ;) - its to the point where I'm ready to
test sending and receiving packets. I'm having a little trouble
getting the if interfaces set up. When I configure all the interfaces
(2 dec units and 2 3com units), the dec boards dc1 and dc2 initialize
and work OK. The 3com units el1 and el2 both fail saying "Can't set
address: File exists". The ip addresses and netmasks are OK & valid.
The error is identical if I set up only dc1 and el2.
I have a few questions;
- what is being tested such that a "file exists" error is returned
when the test fails. Following the ioctl call, it seems to dive
into the bowels of the ip stack- beyond my competence to trace at
this point.
- what is the significance of the unit number beyond differentiating
units that employ the same driver
- what printf style function can I use that won't mix its output with
diagnostic messages coming from the ip stack- both printf and printk
seem to do mingle their outputs.
Thanks,
Gregm
