I download a bsp but can't install it
Aaron J. Grier aaron at frye.com
Tue Apr 22 16:57:53 UTC 2003
On Tue, Apr 22, 2003 at 01:53:51PM +0800, elieli wrote:
> I download a bsp (made by David J. Fiddes from his
> homepage:http://www.users.surfaid.org/~fiddes/coldfire/) that
> developed for coldfire 5307.
> And then I (1) copied sbc5307 into rtems-4.5.0/c/src/lib/libbsp/m68k/
> and (2) copied sbc5307.cfg into rtems-4.5.0/make/custom/ is it enough?
> But when I make all install, it would be error 1 said can't find rule
> to make and preinstall.  Why?are there some works that I failed to do?
it's possible you need to regenerate the autoconf/automake files by
running "./bootstrap" at the top level of the RTEMS source tree.  it
would also help us if you could cut-and-paste your configure line and
the exact failure you are getting.
  Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron at frye.com
