pc386dx exception 6 was Re: 4.6.0pre2 and docs released
Angelo Fraietta
angelo_f at bigpond.com
Thu Apr 24 04:54:25 UTC 2003
>>>>I am not actually using anything in the application. I included the
>>>>iostream header but didi not use anything to make it fail. If I remove
>>>>the include directive, the app runs and is reduced by about 1050K.
>>>I suspect it is just calling some constructor. It doesn't surprise me
>>>that the applciation shrinks.
>If it worth anything, I tried the follwing.
>I rebuilt the toolset using gcc3.2.2 and Newlib 1.10 with an identical result
>I then rebuilt the toolset using gcc3.2 and Newlib 1.11
>With the iostream directive I got the following message
>RTEMS: rtems_gxx_mutex_init
>RTEMS: fatal error, exiting
>Without the iostream include it works fine
I just did some more tests. The error that caused the rtems_gxx_mutex_init failure did not run on on the pentium machine.
I attmpted to do the same test with gcc3.2 and newlib 1.10 (which is working for my application) and I got the same result (rtems_gxx_mutex_init).
If, however, I perform a test using one of my own applications (where I originally found the fault), if I include iostream I get the exception 6. My real application, however, does not include iostream anywhere in it and subsequently runs fine.
If I use gcc3.2 with newlib 1.11, my application runs (however, I never include iostream anywhere)
If I use gcc3.2.2 with newlib 1.11, the application bloats from 462K to 621K and crashes with the exception 6. There is no change in my source whatsoever
I think that there may be two problems here.
If you want me to run any more tests or sequences, let me know.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030424/0de11c32/attachment.html>
