closed PR summary report format
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Apr 24 19:41:35 UTC 2003
Hi,
This is a first attempt at producing a report on the PRs closed
from one release to the next. I want to start producing one
of these for every tarball cut. This is the report for PRs
closed between 4.6.0pre1 and 4.6.0pre2.
How does it look? Comments appreciated.
338/rtems - rtems_io_lookup_name is not re-enterant
348/bsps - MTX603e BSP missing libcpu support for CPU model
349/bsps - PowerPC BSP and Libcpu Fixes
351/networking - fix bootp leak
352/rtems_misc - add FP attribute to main shell task
353/bsps - pc386 BSP -- allow override of network device name
354/networking - libchip- Intel EEPRO autodetect more
356/bsps - make rtems + powerpc/shared BSP [more] sysv/eabi
compliant
357/rtems_misc - Single line patch to rtems_termios_open() in
termios.c
360/bsps - incorrect IRQ priority settings in powerpc/shared
BSPs
367/filesystem - correct various bugs in FAT Filesystem
implementation
368/filesystem - IDE driver support for pc386 and mbx8xx added
374/networking - PR270 patch wrong and malloc message suppression
378/bsps - powerpc gen405 bsp_specs
379/bsps - nameclash fix: powerpc-shared BSP should use
cpukit/printk not its own
380/rtems_misc - vmeUniverse driver update
381/rtems - libc_start_hook corrupt initial thread stack
registers with recent gcc/newlib
383/bsps - powerpc: BSP_spuriousIntr
385/filesystem - pointers are not moved in ramdisk driver
387/rtems_misc - libchip/ide messed up
388/networking - snprintf vs. cpukit/libnetworking
389/rtems - Doubts on cpukit/libcsupport/src/no_posix.c
joel at OARcorp.com On-Line Applications Research
