termios
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Mon Apr 28 18:37:34 UTC 2003
Hello,
ok, I will open a PR on this, and we will see
whether either of our solutions will do the job
(without break anything else :-)
wkr,
	Thomas.
> Thomas Doerfler wrote:
> > Hello,
> > I think you refer to the loop starting with
> >                 while (tty->rawInBuf.Head != tty->rawInBuf.Tail) {
> > in function "fillBufferQueue" in termios.c.
> > IMHO a solution would be to limit the loop to the cases, when
> > the variable "wait" ist still TRUE, so a replacement for the
> > upper line would be
> >                 while (wait && (tty->rawInBuf.Head != tty->rawInBuf.Tail)) {
> I think either will work but changing the semantics of the checks being
> made
> separately scares me a bit without doing more analysis.
> I think Wolfram's solution is correct and less likely to perturb things.
> Can one of you file a PR once the patch is tested?
> FWIW my first job out of college was porting the System V TTY driver
> to an embedded environment.  It was an intelligent serial controller
> and the card pretty closely mapped section 2 system calls.  The code
> was incredibly complicated and the RTEMS termios driver is a piece of
> cake to read compared to that. :)
> --joel
> > wkr,
> >         Thomas Doerfler.
> > > Hello,
> > > we are struggling with the termios system in the moment and we need the
> > > help of the community.
> > > either there is a missunderstanding of cannonical processing by us or a
> > > real bug in the termio system.
> > > the function fillBufferQuue() is responsible to transfer from raw input
> > > buffer into cooked buffer and all the control character processing is
> > > handled by iproc(). when iproc() signals a completed line by returning a
> > > one, fillBufferQueue does not return to the caller with this line in the
> > > cooked buffer, but remains in its loop and appends all further
> > > characters (after cannonical processing) to the cooked buffer. IMHO
> > > fillBufferQueue should return immediately after an NL, EOF, EOL or EOL2
> > > was added to cooked buffer.
> > > this behaviour could be accomplished by adding a break instruction after
> > > the wait = 0; instruction after calling siproc() in cannonical processing.
> > > Schöne Grüße aus Reutlingen
> > > Wolfram Wadepohl
> > > Entwicklung
> > > INDUMAT GmbH & Co. KG
> > > Transport- und Lagersysteme
> > > Dieselstraße 6
> > > D-72770 Reutlingen - Betzingen
> > > Tel.  +49 (0)71 21/5 14-2 89
> > > Fax   +49 (0)71 21/5 14-2 99
> > > eMail W.Wadepohl at indumat.de
> > > WWW   http://www.indumat.de
> > > Bitte senden Sie mir keine Word- oder PowerPoint- (tm Microsoft)  Anhänge.
> > > Senden Sie mir einfachen Text, HTML oder PDF.
> > > Siehe http://www.fsf.org/philosophy/no-word-attachments.de.html
> > IMD Ingenieurbuero fuer Microcomputertechnik
> > Thomas Doerfler           Herbststrasse 8
> > D-82178 Puchheim          Germany
> > email:    Thomas.Doerfler at imd-systems.de
> > PGP public key available at: http://www.imd-
> > systems.de/pgp_keys.htm
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
