etherboot options needed to dhcpd/tftp boot rtems *.bt images
Jack Cawkwell J.Cawkwell at open.ac.uk
Fri Apr 11 08:17:00 UTC 2003
Hi,
I am trying to boot rtems images using dhcpd/tftp/etherboot
and would like to know which of the etherboot options are needed.
Booting for example: hello.bt. Appended are some of the options
for the latest etherboot (5.1.7).
Thanks, Jack
TAGGED_IMAGE
  Add tagged image kernel boot support (recommended)
AOUT_IMAGE
  Add a.out kernel boot support (generic)
ELF_IMAGE
  Add generic ELF kernel boot support (recommended)
EL64F_IMAGE
  Add generic ELF64 kernel boot support (useful for > 4GB disks).
WINCE_IMAGE
  Add the ability to boot WINCE.... now only sis630 OK!
FREEBSD_PXEEMU
  Add the ability to boot PXE images... only FreeBSD supported
Support for PXE emulation. Works only with FreeBSD to load the
kernel via pxeboot, use only with DOWNLOAD_PROTO_NFS
X86_BOOTSECTOR_IMAGE
  Add the ability to boot 512 byte x86 boot sectors
IMAGE_MULTIBOOT
  Add Multiboot image support (currently only for ELF images)
IMAGE_FREEBSD
  Add FreeBSD image loading support (requires at least -DAOUT_IMAGE
  and/or -DELF_IMAGE)
FREEBSD_KERNEL_ENV
  Pass in FreeBSD kernel environment
AOUT_LYNX_KDI
  Add Lynx a.out KDI support
