(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Angelo Fraietta angelo_f at bigpond.com
Tue Apr 15 07:36:07 UTC 2003
Angelo Fraietta wrote:
> I have implemented this into my app, hwoever, when I try to examine
> the file, I get zero bytes.
> I did the following
>     fd = open(nvram_file,O_WRONLY | O_CREAT | O_TRUNC,S_IREAD|S_IWRITE);
>     if (fd <0)
>             printf ("Unable to open %s\r\n", nvram_file);
>     else
>             unsigned i;
>             for (i = 0; i < 255; i++)
>                     char c = (char) i;
>                     int bytes = write(fd, &c, 1);
>                     printf ("Wrote %u bytes \r\n", bytes);
>             close(fd);
>             printf ("Close file\r\n");
ignore this next line as this was an attempt to see if re-initialising
would help
>             fileio_part_table_initialize ();
> I got the correct output to my display, however, the file written is
> zero bytes. Any idea as to what I am doing wrong?
> Thomas Doerfler wrote:
>>Hello,
>>>I got the program working and it worked fine with my flash disk.
>>>I did, however, have to type my filenames in UPPER CASE. I don't know
>>>whether this is something peculiar with the DIMMPC flash IDE or not.
>>I am glad things are working for you now. The upper case
>>matter is a bit strange. Per definition, DOS filenames are
>>case insensitive. They are stored in upercase in the dorectory
>>but I am sure I open my files with a lowercase filename given
>>and the functions definitively find the right file and open
>>and read/write it.
>>Could this be a problem on the MAC side?
>>I don't know, if the patches will make it into the next
>>release, we had a discussion with Joel about it. I think they
>>will not break anything that was working without the
>>patches...
>>wkr,
>>	Thomas.
>>>I also modified so I wrote a binary stream from 0x00 to 0xFF and tested
>>>that it was uncorrupted. That worked fine too.
>>>So effectively, this is working fine for me.
>>>Do you know whether this will be included in the next snapshot?
>>>>Hello,
>>>>no it has nothing to do with ada, it is a web-
>>>>based bug tracking system. Just try it out,
>>>>login/password is guest/guest...
>>>>wkr,
>>>>	Thomas.
>>>>>Is the gnats system only ada? I am using C/C++, so will I be able to use
>>>>>these?
>>>>>>Hello Angelo,
>>>>>>the "sample" program is located in the patch filed in the gnat
>>>>>>system as PR369. So if you go to
>>>>>>http://www.oarcorp.com/cgi-bin/gnatsweb.pl
>>>>>>and inspect PR369 and download/apply the patch and then look
>>>>>>into c/src/tests/samples/fileio, you will see the sample
>>>>>>application.
>>>>>>BTW, you will also need PR368 and PR367 to get everything
>>>>>>running (these PRs contain modifications for the DOSFS code
>>>>>>and added drivers for PC386 and MBX8xx).
>>>>>>wkr,
>>>>>>	Thomas.
>>>>>Angelo Fraietta
>>>>>PO Box 859
>>>>>Hamilton NSW 2303
>>>>>Home Page
>>>>>http://www.users.bigpond.com/angelo_f/
>>>>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>>>>There are those who seek knowledge to be known by others - that is VANITY
>>>>>There are those who seek knowledge in order to serve - that is LOVE
>>>>>   Bernard of Clairvaux (1090 - 1153)
>>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>>Thomas Doerfler           Herbststrasse 8
>>>>D-82178 Puchheim          Germany
>>>>email:    Thomas.Doerfler at imd-systems.de
>>>>PGP public key available at: http://www.imd-
>>>>systems.de/pgp_keys.htm
>>>Angelo Fraietta
>>>PO Box 859
>>>Hamilton NSW 2303
>>>Home Page
>Angelo Fraietta
>PO Box 859
>Hamilton NSW 2303
>Home Page
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20030415/685502de/attachment-0001.html>
