Microwindows!
Erwin Rol
erwin at muffin.org
Mon Apr 21 14:50:34 UTC 2003
On Mon, 2003-04-21 at 16:40, Bert wrote:
> Hi, i encountered some problems when installing Microwindows on RTEMS.i found that there are some
> bugs in Microwindows for RTEMS and fixed, but still failed.
> If you have succeeded in the installation, are you kind enough to tell me the versions of Microwindows/RTEMS and how to install?
Before ppl can help you , you better explain what kind of hardware you
use. Linke CPU type, Video-chip type etc. else it will just be guessing.
> my versions: linux-7.2, Microwindows-0.89,
there is no linux 7.2. there is a suse distribution 7.2 there is a
redhat distribution 7.2 and there are probably more distributions with
version number 7.2 :-)
- Erwin
> RTEMS-20030128
Dipl.-Ing. Erwin Rol - Software Engineering
tel: +49-(0)8024-479377 gsm: +49-(0)171-6929198 fax: +49-(0)8024-479379
email: erwin at muffin.org
Type: application/pgp-signature
Desc: This is a digitally signed message part
URL: <http://lists.rtems.org/pipermail/users/attachments/20030421/be7388cd/attachment-0001.bin>
