gcc 3.2.3 previews
Eric Valette
eric.valette at free.fr
Mon Apr 21 16:28:38 UTC 2003
Joel Sherrill wrote:
>>I've been following it closely and can report it works allthough I also
>>used a cvs version of newlib just to go forward...
> What was wrong with newlib? I have been using 1.11.0 with the rtems
> patch.
> Thanks for the reply.
As you know the last famous bug with gcc-3, was due to a conjunction of
changes beween newlib and gcc-3. So when trying to hunt the bug (as
nobody else voluntered) in order to avoid re-discover something already
fixed, I switched to a more recent newlib and gcc via CVS. And BTW, I
think that newlib has changed so much in a recent past that 1.11.0 is
already old now.
I have seen some fixes on floating point problem incorporated for
example and maybe you should consider giving a identified recent
snapshot along with rtems...
__
/ ` Eric Valette
/-- __ o _. 6 rue Paul Le Flem
(___, / (_(_(__ 35740 Pace
Tel: +33 (0)2 99 85 26 76 Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
