pc386dx exception 6 was Re: 4.6.0pre2 and docs released
Angelo Fraietta
angelo_f at bigpond.com
Mon Apr 28 02:21:33 UTC 2003
Steven Johnson wrote:
> Angelo,
> You put it in your make file. If you link your final app with GCC, you
> need to pass -Wl,'--gc-sections' to g++.
> It also doesn't do anything unless you link with -static. (Which I
> would guess you would be doing anyway for a final link.)
> You will also need to put KEEP() around your .init section. (As well
> as others potentially)
> You put this in your link script for your program.
> Steven
My makefile looks like this
# $Id: Makefile,v 1.18 2003/04/28 01:54:09 angelofraietta Exp $
# Templates/Makefile.leaf
# Template leaf node Makefile
EXEC=smart.exe
# C source names, if any, go here -- minus the .c
C_PIECES=diags fsmount
C_FILES=$(C_PIECES:%=%.c)
C_O_FILES=$(C_PIECES:%=${ARCH}/%.o)
# C++ source names, if any, go here -- minus the .cc
CC_PIECES=rtems_init \
midioutput \
scheduler \
rtems_simulator \
commtasks
CC_FILES=$(CC_PIECES:%=%.cpp)
CC_O_FILES=$(CC_PIECES:%=${ARCH}/%.o)
H_FILES=
# Assembly source names, if any, go here -- minus the .S
S_PIECES=
S_FILES=$(S_PIECES:%=%.S)
S_O_FILES=$(S_FILES:%.S=${ARCH}/%.o)
SRCS=$(C_FILES) $(CC_FILES) $(H_FILES) $(S_FILES)
OBJS=$(C_O_FILES) $(CC_O_FILES) $(S_O_FILES)
PGMS=${ARCH}/$(EXEC) #${ARCH}/xxx-another-one
# List of RTEMS managers to be included in the application goes here.
# Use:
# MANAGERS=all
# to include all RTEMS managers in the application.
MANAGERS=io event message rate_monotonic semaphore timer
include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
include $(RTEMS_CUSTOM)
include $(RTEMS_ROOT)/make/leaf.cfg
# (OPTIONAL) Add local stuff here using +=
DEFINES += -D_E_STL
CPPFLAGS += -I ../../../estl
CPPFLAGS += -I ../engine
CPPFLAGS += -I ../engineinterface
CPPFLAGS += -I ../hal_include
CPPFLAGS += -I ../link_driver
CPPFLAGS += -I ../../../threads/source
CPPFLAGS += -I ../../../mididriver
CPPFLAGS += -I ../../../mididriver/hal_rtems
XCPPFLAGS +=
CFLAGS +=
# CFLAGS_DEBUG_V are used when the `make debug' target is built.
# To link your application with the non-optimized RTEMS routines,
# uncomment the following line:
# CFLAGS_DEBUG_V += -qrtems_debug
LD_PATHS += #xxx-your-EXTRA-library-paths-go-here, if any
LD_LIBS += ../engine/$(ARCH)/sm_engine.a
LD_LIBS += ../engineinterface/$(ARCH)/sm_engineinterface.a
LD_LIBS += ../link_driver/$(ARCH)/sm_link_driver.a
LD_LIBS += ../link_driver/hal_rtems/$(ARCH)/sm_comm.a
LD_LIBS += ../../../threads/source/$(ARCH)/sm_rtems_active.a
LD_LIBS += ../../../threads/source/hal_rtems/$(ARCH)/sm_rtems_thread.a
LD_LIBS += ../../../mididriver/hal_rtems/$(ARCH)/rtems_midi.a
LDFLAGS +=
# Add your list of files to delete here. The config files
# already know how to delete some stuff, so you may want
# to just run 'make clean' first to see what gets missed.
# 'make clobber' already includes 'make clean'
CLEAN_ADDITIONS +=
CLOBBER_ADDITIONS +=
all: ${ARCH} $(SRCS) $(PGMS)
${ARCH}/$(EXEC): ${OBJS} ${LINK_FILES}
$(make-cxx-exe)
# Install the program(s), appending _g or _p as appropriate.
# for include files, just use $(INSTALL_CHANGE)
install: all
$(INSTALL_VARIANT) -m 555 ${PGMS} ${PROJECT_RELEASE}/bin
What ammendments would you make to remove all unnecessary code during
the link.
>>> To remove anything that is not used, you need to pass --gc-sections
>>> to linker. See ld manual for details. I don't think it removes
>>> absolutely everything that isn't used, but it removes a lot. Also
>>> look up KEEP directive for linker script as you may need this for
>>> .init section.
>> Is this something that I can do from my Makefile or is it something
>> that needs to be done from within the BSP files.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
