pc386dx exception 6 was Re: 4.6.0pre2 and docs released
Angelo Fraietta
angelo_f at bigpond.com
Mon Apr 28 04:16:32 UTC 2003
Steven Johnson wrote:
> Angelo,
> Change LDFLAGS += to be
> LDFLAGS += --gc-sections
This one did not work.
> Unless LD Flags is passed to gcc or g++ and not ld, in which case use:
> LDFALGS += -Wl,'--gc-sections'
This did work, however, I got an exception 13 after the device drivers
loaded
> I don't actually use GNU Make. I Use JAM Instead. The Make File
> (JamFile) is a lot cleaner, and I haven't used GNU Make files (other
> than what comes with RTEMS and other stuff in our own development for
> a long time, but this is where I would try. You will need to look at
> the output of running Make to see if the link is perfromed with ld or
> gcc/g++.
It uses i386-rtems-g++ (I have attached the final link text)
What is interesting is that this did not occur until gcc3.2.1
In GCC3.2, my executables were substantially smaller, and this is why they didn't crash with the exception 6 -- they did not include the code -- unless I added the include <iostream> directive. I don't have the directive anywhere in my code but it must still be including the iostream. Maybe there is a flag that allows me to not add it.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20030428/9cc10bc3/attachment-0001.txt>
