4.6.0pre3 available
gregory.menke at gsfc.nasa.gov
Mon Apr 28 16:33:47 UTC 2003
Ralf Corsepius writes:
> Am Mon, 2003-04-28 um 17.21 schrieb gregory.menke at gsfc.nasa.gov:
> > Chris Johns writes:
> > > Joel Sherrill wrote:
> > > > Now we can worry about what real problems need to be
> > > > there. :)
> > > None for me. :-)
> > > I have successfully tested C & C++ (STL) apps with this release using the released
> > > gcc-3.2.3 + newlib-1.11.0 + binutils-2.13.2.1 tool set for the Coldfire processor
> > > (5206e + 5272).
> > > I used the multilib option and built no BSPs (gmake RTEMS_BSP=""). The multilib
> > > option is excellent and removes my need to use the bare BSP.
> > > Excellent effort.
> > Please pardon my possibly stupid question, but what is the multilib
> > and why is it needed?
> multilibs are a gcc feature to build libs multiple times using different
> sets of compilation flags for different sub-targets, resulting into
> libraries being optimized for different sub-targets.
> Configuring the RTEMS source tree with --enable-multilib builds the
> cpukit multilib'ed, ie. one time each for each multilib-sub-target of
> gcc.
What is an example of a sub-target?
> > Whenever I've been building gcc (for powerpc or
> > mips) and have forgotten to disable it, I usually end up with gcc
> > build problems.
> I don't know what you are doing, but all rtems-gcc's on ftp.rtems.com
> have been built with multilibs enabled.
I may not know either.. But, we cm everything & support multiple
build platforms, so we have our own gcc & rtems build scripts.
Is --enable-multilib supposed to be used on gcc and rtems, or just one
or the other?
Thanks,
Gregm
